No heat 2002 sonata, ? relay, where is it
Old Nov 13, 2008 | 10:45 AM
dsrming13's Avatar
Default No heat 2002 sonata, ? relay, where is it
i recently changed my battery and since then i have no heat/ a/c. I have check al fuses. Is there a relay i should check
Old Nov 25, 2008 | 08:49 AM
igotnothin's Avatar
Default RE: No heat 2002 sonata, ? relay, where is it
If you just changed your batery, i would check the fuses under the hood if you have not done so...
There are relays, but i doubt you blew both of the relays for the blower.. There is typicaly one for the lower fan settings, and one for the highest fan setting.. Id check the fuses under the hood...
chrismgan
Aug 31, 2019 11:51 PM
SantaFe_owner
Sep 3, 2012 10:25 AM
Screamin_99
Oct 6, 2009 10:47 PM
KretschJ
Jul 28, 2009 03:41 PM
dsrming13
Nov 13, 2008 10:50 AM
