Noisy Idler Pulley
Old Nov 4, 2010 | 04:59 PM
oknaz's Avatar
Default Noisy Idler Pulley
I have a solution to those of you that might have a high pitched idler pulley behind the Alt . I've did this and it worked ...Remove tire ...Then that belt cover that is bolted to the inner finder ..Start engine and spray PB directly on the idler pulley (Center behind the large washer) . The PB lube will soak in behind the washer as the engine is running . It's a temp fix but it might last a long time . Just my .02
briantuc
Aug 3, 2014 06:01 PM
framfilter
Oct 6, 2011 09:49 AM
96beast
Feb 7, 2010 11:22 PM
audioquest
Feb 2, 2007 01:44 PM
tduncan
Jan 16, 2007 12:44 AM
