Purge Flow Valve
Old Mar 30, 2010 | 07:50 AM
long71's Avatar
Default Purge Flow Valve
I am getting a P0441 code(evap emission control system purge flow fault)on my '05 Tucson GLS. Doing some online research it says my purge flow valve is probably stuck and needs replacing. I am going to order the part online but was just wondering where it is located and is it easy enough to change myself.
Old Mar 30, 2010 | 11:24 AM
5yr/60,000 warranty part if dates/mileage meet criteria
4cyl is located under the intake/throttle body area I believe, V6 is behind/under the intake.. look at your part in hand, and see it on the engine, has a 2 wire connector on it, hose to intake manifold, other hose takes off to bulkhead and on to rear of car.
santafe2001
Nov 21, 2010 09:47 AM
vaughn1112
Jul 30, 2009 02:32 PM
rwolfe
Apr 21, 2009 06:40 AM
bryanbuchi
Feb 27, 2009 06:42 PM
phoenixsun
Jun 9, 2007 10:30 AM
