sound system tech issues
Old May 17, 2005 | 12:44 AM
benihana's Avatar
Default sound system tech issues
I just got the 2005 Sonata LX V6. I also recently upgraded the soundsystem with the new Kenwood cd mp3 player, High wattage rockford 6.5"s for the front, two planet audio 10"s and a Rockwood 700 watt 4 channel amp. Right now 2 channels are powering the rockfords in the front and 2 channels are going to the subs. I eventually plan on replacing the 6/9's in the back deck and using the 4 channel amp for all the in car speakers, and getting a new 2 channel for the subs.
My problem is I have some new 6/9's but don't know how to remove the speaker grating on the back deck to get at the stock speakers to remove them. I assume they have to be removed from the topside since they are drilled in that way.
Any insight would be great, I'm dying to get the new speakers in and try em out.
Thanks.
Old Jun 27, 2005 | 06:48 PM
Patrick's Avatar
Administrator
Default RE: sound system tech issues
are you sure that they wont remove from the trunk side? i know that on my nonner, i can fodl the back seats down, and lift the cover away, that exposes the 6x9s
Old Jun 30, 2005 | 11:54 PM
hyundai tech's Avatar
In order to gain access to the speakers you have to fold the seats down.Remove the black facia behind the rear seats. Remove the
3rd brake light assy and then carefuuly lift up the rear tray.Sometimes removing the rear quarter trim panels helps get room. Be sure to route the wiring harness properly that goes across the rear tray.You can route it incorrectly and cause it to rub against the sheet metal causing a short. This job takes about 30-45 minutes to complete for the beginner who has never done one.As a tech and have had several apart it takes me about 20 minutes to replace both rear speakers.
jesselscott
Jul 8, 2010 08:57 AM
jte15904
Feb 17, 2010 04:02 PM
kenbrenbets
Apr 7, 2008 09:40 PM
ravisher78
Oct 29, 2007 11:08 AM
JimJudi
Aug 26, 2006 11:02 PM
