stearing rack
Old Jan 18, 2009 | 04:19 PM
roland2k1's Avatar
Default stearing rack
I have leaking oil from stearing rack its seems to be coming from a seal by the bulkhead so its very hard to get too, can anyone help? is there a sort cut to this or do I need to take the rack out?
Kind regards
Martin "ps she is a 1997 cop 1600
Old Jan 18, 2009 | 07:25 PM
jsinton's Avatar
Banned
Default RE: stearing rack
I never tried to just replace a seal, but I have taken them out and replaced them. I suppose you could just replace the seal, but you have to remove the tie rod end, unband the bellows, etc. I'm not sure how the tie rod comes out. It's probably easier just to replace the rack as a unit. There's instructions on how to do it for a '99 Elantra:
1999 > G 2.0 DOHC > Steering System DISASSEMBLY1.Remove the tie rod end from the tie rod.[/align]2.Remove the dust cover from the ball joint.[/align]3.Remove the bellows band.[/align]4.Remove the bellows clip.[/align]5.Pull the bellows out toward the tie rod.[/align]Check for rust on the rack when the bellows are replaced.[/align]6.Remove the feed tube from the gear housing.[/align]7.While moving the rack slowly, drain the fluid from the gear housing.[/align]8.Remove the end plug.[/align]9.With the pinion turned clockwise until the rack is locked, remove the self-locking nut.[/align]10.Unstake the tab washer between the tie rod and rack with a chisel.[/align]11.Remove the tie rod from the rack.[/align]Remove the tie rod from the rack, taking care not to twist the rack.[/align]12.Remove the yoke plug locking nut.[/align]13.Using special tool, remove the yoke plug.[/align]14.Remove the rack support spring, rack support yoke and bushing from the gear box.[/align]15.Remove the valve body housing by loosening the two bolts.[/align]16.Turn the rack stopper clockwise until the end of the circlip comes out of the slot in the gear housing.[/align]17.When the end of the circlip comes out from the notched hole of the housing rack cylinder, turn the rack stopper counterclockwise and remove the circlip.[/align]18.Remove the rack stopper, rack bushing and rack from the gear housing by moving it toward the pinion side.[/align]When the rack has been removed, be sure to replace the housing side oil seal.[/align]19.Remove the O-ring from the rack bushing.[/align]20.Remove the oil seal from the rack bushing.[/align]21.Remove the valve body from valve body housing with a soft hammer.[/align]22.Use the special tool to remove the oil seal and ball bearing from the valve body housing.[/align]23.Use the special tool to remove the ball bearing from the gear housing.[/align]Be careful not to damage the pinion valve cylinder inside of the gear housing.[/align]24.Use the special tool (09517-21400) to remove the needle bearing from the gear housing.[/align]25.Use the special tools to remove the oil seal from the gear housing.[/align]Be careful not to damage the rack cylinder inside of the gear housing.[/align] [/align] findme('); findme('); findme('); 1999 > G 2.0 DOHC > Steering System INSPECTION1.Rack[/align]a.Rack tooth face damage or wear[/align]b.Oil seal contact surface damage[/align]c.Rack distortion[/align]d.Oil seal ring damage or wear[/align]e.Oil seal damage or wear[/align]2.Pinion valve[/align]a.Pinion gear tooth face damage or wear[/align]b.Oil seal contact surface damage[/align]c.Seal ring damage or wear[/align]d.Oil seal damage or wear[/align]3.Bearing[/align]a.Seizure or abnormal noise during bearing rotation[/align]b.Excessive play[/align]c.Missing needle bearing[/align]4.Others[/align]a.Damage of the gear housing cylinder bore[/align]b.Boot damage or deterioration[/align] [/align] findme('); findme('); findme('); 1999 > G 2.0 DOHC > Steering System INSTALLATION1.Screw in tie rod end to have its right and left length as illustrated.[/align]Lock With lock nut.[/align]2.Push in the power steering gear box assembly from the right side of the vehicle.[/align]3.Install the dust cover mounting plate.[/align]4.Connect the dust cover to its mounting plate with a new strap.[/align]5.Connect the steering gear box assembly to the steering column and shaft assembly[/align]This work should be done by two persons. While one is pushing the gear box assembly toward the steering column and shaft assembly from underside of the vehicle, the other one is connecting the ear box to the steering column and shaft.[/align]6.Remaining installation procedure is the reverse order of removal.[/align]7.After installation, bleed the system.[/align] [/align] findme('); findme('); findme('); 1999 > G 2.0 DOHC > Steering System REASSEMBLY1.Apply the specified oil to the entire surface of the rack oil seal.[/align]2.Install the backup washer and oil seal to the specified position in the gear housing.[/align]3.Apply the specified grease to the entire surface of the needle bearing.[/align]4.Set the scribed side of the needle bearing in the special tool and install it into the gear housing (until the special tool contacts the gear housing).[/align]Note the direction of the needle bearing.[/align]5.Apply the specified grease to the ball bearing and install using the special tool.[/align]Always use a new bearing.[/align]6.Apply the specified oil to the entire surface of the rack bushing oil seal.[/align]7.Install the oil seal in the rack bushing.[/align]8.Apply the specified oil to the entire surface of the O-ring and install it in the rack bushing.[/align]9.Apply the specified grease to the rack teeth and wrap with vinyl tape.[/align]Do not plug the vent hole in the rack with grease.[/align]10.Wrap the rack end with vinyl tape, apply a coating of the specified fluid, and then install the rack bushing and rack stopper.[/align]Do not allow oil seal retainer spring to slip out.[/align]11.Push in the rack stopper until the circlip groove of the rack stopper is aligned with the notched hole of the rack housing. Install the circlip while turning the rack stopper.[/align]The circlip end should not be visible through the notched hole of the rack housing.[/align]12.Using special tool, install the oil seal and the ball bearing in the valve body.[/align]13.When installing seal rings, press firmly into valve groove. Apply specified fluid.[/align]14.Apply the specified oil and grease to the pinion valve assembly and install in the gear housing assembly.[/align]15.Apply the specified oil and then use the special tool to install the seal in the valve body housing.[/align]16.Install the valve body assembly with the seal ring to the gear box.[/align]17.Install the tab washer and the tie rod and stake the tab washer end at two points over the tie rod.[/align]a.Align the tab washer pawIs with the rack grooves.[/align]b.Always use a new tab washer.[/align]18.With the pinion turned all the way clockwise, tighten the self-locking nut.[/align]Always use a new nut.[/align]19.Apply semi-drying sealant to the threaded section of the end plug and tighten to the specified torque.[/align]20.Stake the end plug at two points on its circumference with a punch.[/align]21.Install the bushing, rack support yoke, rack support spring and yoke plug in the order shown. Apply semi-drying sealant to the threaded section of the yoke plug before installation.[/align]22.With the rack placed in the center position, attach the yoke plug to the gear housing. Tighten the yoke plug to, using the special tool. Loosen the yoke plug approximately 30 to 60°, and tighten the locking nut to the specified torque.[/align]23.Tighten the feed tube to the specified torque and install the mounting rubber using adhesive.[/align]24.Apply the specified grease to the bellows mounting position (fitting groove) of the tie rod.[/align]25.Install the attaching band to the bellows.[/align]When the bellows are installed, a new band must be used.[/align]26.Install the bellows in position, taking care not to twist it.[/align]27.Fill the dust cover inner side and lip with the specified multipurpose grease, and place the dust cover in position with the clip ring attached in the groove of the tie rod end.[/align] [/align] findme('); findme('); findme('); [align=left] [/align]
Old Mar 8, 2009 | 04:21 AM
roland2k1's Avatar
Default thanks to jsinton/RE: stearing rack
Thanks for your help on this matter its very kind of you ,All I hope is that someone maybe able to tell me if I can get replacement seals for it . Once again Thanks
Kind regards
Martin
Old Mar 8, 2009 | 07:48 AM
jsinton's Avatar
Banned
Did you try to call the dealer. It's probably something you can only get from the dealer.
Old Mar 10, 2009 | 02:51 AM
roland2k1's Avatar
do you know how easy it it to remove a rack and if there is a sort cut to doing this?
Can again I thank jsinton for his help as he always seems to be able spend the time to come back to me.
Kind regards
Martin
Old Mar 10, 2009 | 04:59 AM
jsinton's Avatar
Banned
No, it's not really an easy job, nor fun. It's one of those things you just can't think about how hard it is, you just get your hands dirty. Did you take it to the shop for an estimate?
Old Mar 13, 2009 | 03:36 AM
roland2k1's Avatar
Thanks once again I will just have to grin and get on with it
Kind regards
Martin
Elantra
May 1, 2008 11:51 PM
gijf430
Jan 6, 2008 10:26 PM
Ken M
Aug 1, 2007 05:32 PM
waterrockets
Dec 7, 2006 01:01 AM
mfleming
May 6, 2005 08:40 PM
