Tourque Specs for 2015 Elantra
Old Dec 10, 2019 | 07:46 PM
Mike Cooper's Avatar
Default Tourque Specs for 2015 Elantra
Im replacing a front right wheel bearing on my 2015 Elantra. Cant find the tourque specs anywhere? I need the axle nut and how tight the ball joints, rod ends and strut bolts have to be. Any help would be great.
Old Dec 13, 2019 | 03:29 PM
I can't supply the torque specs you seek, but I can hope to make you aware of some things just in case you forgot.
We never reuse the axle nut replace it with a new one.
If you disturb any alignment settings, you will need to have the front end realigned when done.
Ball joints should be tightened in the neutral/straight ahead position if replacing.
Remember to support the caliper and not to allow it to hang by the brake hose.
Some bearings need to be pressed out and new ones pressed in. Do you have the equip to do that?
Otherwise, be careful and do it right and do it once.
djdonte
Feb 6, 2022 04:02 AM
dkubissa
Jul 16, 2021 05:17 AM
ata10
Nov 16, 2014 07:23 AM
bernd
Mar 12, 2009 10:35 AM
