transmission problems
Old Apr 10, 2006 | 10:04 AM
meast's Avatar
Default transmission problems
My 2002 Accent GL is having trouble switching gears. As I try to accelerate, the car goes really slowly then suddenly "lurches" into the new gear. When I brake, as it is about to come to a complete stop, it often "lurches" forward again. Also, it drops down in speed big time when going up a hill. I will press on the accelorator but it still goes slow. Any suggestions?
Old Apr 10, 2006 | 04:07 PM
flave1's Avatar
Default RE: transmission problems
this is probably a daft question but have you checked the oil level in the transmission? remember to check it when in neutral not park!
Old Apr 12, 2006 | 09:05 PM
Brant's Avatar
I would agree with Flave 1. Check the level of the tranny fluid. It probably wouldn't hurt to have the tranny fluid flushed along with the filter changed.
Good Luck,
Brant
Old Apr 12, 2006 | 10:31 PM
gadgetman's Avatar
I would have it scanned and ck the 2 speed sensors and ck the trans fluid temp sensor. maybe there are some trans codes there. The shifting is controlled by a computer.
nygt
Feb 24, 2019 10:32 AM
tszshingt
Jan 16, 2010 01:41 PM
mr63009
Nov 10, 2009 10:22 PM
ejc2180
Oct 7, 2008 03:03 AM
kelvis97
Apr 27, 2008 07:44 AM
