Tucson Windows strange issues
Hello all, hoping someone with a similar problem could point me in the right direction.
I have Tucson, 2013 limited and the electric windows are not working properly. Here is the behavior:
Any idea what the error can be here, why do some switches work in only one direction and the passenger motor doesn't roll up? Thank you for any advice! |
The circuits for all the windows include the master sw on the driver's door. That needs to be verified to provide a good ground for the other widows to operate correctly.
If that circuit is interrupted , say with a broken wire in the driver's door hinge area , some functions will not work. You most likely will need to get into that bundle of wires in the driver's door hinge area and look for a broken wire.there. |
