Wont turn over
My 2002 xg350 won't turn over. I just took it in with the same problem and the shoop said it was the alternator (which had been replaced last year). Now its happening again. I have full power, and jumping doesn't solve it. I checked the battery at autozoen and they said it was fine. I even checked the voltage which reads at 12.85v so well abouve what is needed to turn over the starter. any ideas as to what could be causing this. I don't hear the starter solenoid clicking, but it could just be really quite, as i have to turn the key from inside. Thanks
RE: Wont turn over
Fuse blown?
RE: Wont turn over
not that simple. It started again. but then failed the next time. I'm thinking starter is going. It seems to be more of a problem when temp is high either from driving or sun. I thought it might be the ignition switch, but when i turn it the electronics all respond (i.e. the dash lights and radio turn off momentarily), and i've heard of this kind of thing on other vehicles.
RE: Wont turn over
defo sound like a starter motor fault:D
RE: Wont turn over
ORIGINAL: rrdgirl not that simple. It started again. but then failed the next time. I'm thinking starter is going. It seems to be more of a problem when temp is high either from driving or sun. I thought it might be the ignition switch, but when i turn it the electronics all respond (i.e. the dash lights and radio turn off momentarily), and i've heard of this kind of thing on other vehicles. |
