Wont turn over
Old Aug 10, 2006 | 05:33 PM
rrdgirl's Avatar
Default Wont turn over
My 2002 xg350 won't turn over. I just took it in with the same problem and the shoop said it was the alternator (which had been replaced last year). Now its happening again. I have full power, and jumping doesn't solve it. I checked the battery at autozoen and they said it was fine. I even checked the voltage which reads at 12.85v so well abouve what is needed to turn over the starter. any ideas as to what could be causing this. I don't hear the starter solenoid clicking, but it could just be really quite, as i have to turn the key from inside. Thanks
Old Aug 11, 2006 | 01:55 PM
cofreth's Avatar
Default RE: Wont turn over
Fuse blown?
Old Aug 11, 2006 | 07:52 PM
rrdgirl's Avatar
not that simple. It started again. but then failed the next time. I'm thinking starter is going. It seems to be more of a problem when temp is high either from driving or sun. I thought it might be the ignition switch, but when i turn it the electronics all respond (i.e. the dash lights and radio turn off momentarily), and i've heard of this kind of thing on other vehicles.
Old Aug 18, 2006 | 07:16 PM
flave1's Avatar
defo sound like a starter motor fault
Old Aug 26, 2006 | 04:17 PM
duke's Avatar
ORIGINAL: rrdgirl
have your Hyundai dealer check the ALARM system, it will be able to cut the starter opperation.
E43509
Feb 1, 2009 07:13 PM
idahotiburon
Nov 1, 2007 09:26 PM
hyundaidaughter
Mar 1, 2007 12:58 PM
D_nice
Dec 4, 2005 07:36 PM
Neoimmortal
Aug 19, 2005 04:15 PM
