02 ACCENT FOG LIGHTS/konig wheels
I picked up some small oval fog lights at Walmart I can post photo and they are nice and small ($15) and I made an extra bracket perpendicular to the bracket that came with them Drilled and tapped 1/4-20 holes centered inround cutoutsin front valance and mounted my homemadebrackets there with 1/4 bolts
Now maybe some one could help me I would like to find a place to put a fuse tap in the fuse box under the hood which is goes thru ignition and it will power low voltage side of relay on my remote switch eliminating the need to go thru firewall
I ended up with with wheels and tires for $400 delivered 15" KTP wheels and 195/50/15 Kumho 712 from treadepot.com Great stuff for the price!...it all works- better handling with wider tires and going up with plus 2 tire size looks better too!
as far as foglights I got them at Walmart about $15 and added to provided brackets with brackets I made and mounted them in the holes on my 02 Accent
Call them for specials they changed their website a little bit
Now next question while I got your attention! I have not hooked up the fogs yet I would like to use a fuse tap for the low side of relay a ignition switched power source would be good because I have a remote switch and do not need to go in cab I did the same thing in my Chevy S-10
I have not seached under the hood yet soI am sure I will find somewhere to get power but I thought I'd throw out this question Thanks Mike
Call them for specials they changed their website a little bit Now next question while I got your attention! I have not hooked up the fogs yet I would like to use a fuse tap for the low side of relay a ignition switched power source would be good because I have a remote switch and do not need to go in cab I did the same thing in my Chevy S-10
CrazedFan
Oct 10, 2013 06:36 PM
confined098
Feb 17, 2008 06:55 PM
wellsjo
Oct 5, 2007 01:48 PM
