05 accent no headlights
Old Jan 17, 2019 | 09:51 PM
Suzanne Smith's Avatar
Default 05 accent no headlights
05 accent the headlights only worked on high beam a couple of nights ago the heaterblower motor started going real fast and now no headlights at all
Old Jan 17, 2019 | 11:21 PM
avisitor's Avatar
Never heard of the headlight going out due to the blower motor????
Thought the headlights are ground side switched through the stalk switch on the steering column.
Also thought the blower motor control goes through a resistor pack
When it shorts out the fan goes to high
But, I could be wrong.
Anyway, check the fuses and relay first.
Old Jan 18, 2019 | 11:37 AM
It is important to know if you (or someone you know) will be trying to locate the cause and repair it or just seeking possible corrections.
IF for FYI , there could be several causes
If you (plural) are contemplating to determine the possible cause, then the suggested lengthy procedure could be appropriate. Please advise, thanks.
sunsh!nekk
Nov 16, 2016 10:41 AM
chris1010
Apr 4, 2009 09:04 PM
Manifesto
Jan 7, 2006 05:53 AM
DonnyD
Nov 28, 2005 05:36 PM
coati
Oct 20, 2005 12:50 AM
