07 Hyundai Accent won’t start.
Old Nov 28, 2021 | 09:30 AM
Brian37's Avatar
Default 07 Hyundai Accent won’t start.
My wife’s 07 accent will not start. I have put new fuel pump, 2 of them.for fuel Then put new catalytic converter on for air (new air filter also). Then put coils plugs and crank shaft position sensor for fire. It started ran fine . Let my wife’s son borrow it for work the next day and had to have it towed. Tries to start every now and then . But to avail! I am stumped. If anyone has any advice I would be greatly appreciated.
also put and purge valve. And the fuel pump is running.
Old Nov 28, 2021 | 12:27 PM
Hi Brian,
Since you were able to repair the problem initially, I would suggest you recheck your work. Maybe a wire came off .
Some Crank sensors come with a gasket, was one removed and one installed? Sometimes , two get installed and problems show up.
Old Nov 30, 2021 | 04:29 PM
Brian37's Avatar
Yes I check the old part it still had the o ring . Then pulled new part took o ring off put back in just to check the clearance on the o ring and it still hasn’t hit a lick. Put o ring back and am moving forward. If it gets hot outside it will try and start. Once it gets cold will not fire at all.
Old Dec 1, 2021 | 10:47 AM
Whatever we are looking for appears to be affected by temperature,,,,,,,,,,,,,so,,,,,,,,,,,,,,,,,,,,,,,, ,,if you are sure the vehicle will start at the right temp., one at a time pour some cold water over some of the areas you worked on. The sudden drop in temp might just reveal the faulty area or component. . Just do one at a time and try starting the engine because if you cool down everything , you will be back to guessing.
Old Feb 4, 2022 | 06:19 AM
Gino2³24's Avatar
I had the same thing happened to my car and a mechanic said it was the timing belt
accentguy4912
Jul 5, 2021 11:12 AM
dennis24
Feb 1, 2013 07:47 PM
rjs300
May 31, 2011 09:57 PM
njgirl
Jul 27, 2009 08:51 PM
rstoey
Apr 10, 2007 03:13 PM
