2002 Hyundai Accent 5-speed not starting... again
Old Nov 24, 2015 | 07:41 PM
Dwayne Johnson's Avatar
Default 2002 Hyundai Accent 5-speed not starting... again
I have a 2002 Hyundai accent that I purchased for a couple hundred bucks. It didn't start when I bought it, so I had some work to do. The engine would try to turn over, but wouldn't start. I eventually changed the Crank Shaft Position Sensor and it fixed the problem.
NOW...
Today, as I am driving on the freeway the car poops out as I'm going 60mph. pressing on the gas but nothing, some revving but not going. I was able to coast over to the shoulder. The steering wheel and brakes stiffen up as I am getting over. I still have all power, but now the car won't start.
It is NOT making the same noise it did when it was the CSP sensor. Now it is making a revving kind of squeal when I try to start it up. It's not even getting to a jumpy start attempt. The timing belt is still attached and tight, from what I can see on top. I've seen videos that point to coil packs and starter. I am a novice at troubleshooting, so not sure how to test theses.
Any info on how to test or where to look would be greatly appreciated.
rosie
Aug 26, 2020 03:33 PM
command_z
Jan 4, 2012 07:56 PM
liepinaanna
Off Topic
Nov 17, 2007 10:38 PM
organic53
Jun 29, 2007 07:55 PM
TheDave
May 18, 2007 02:46 PM
