2007 Hyundai Accent Check Engine Light P0301 Cylinder Misfire
Old Feb 27, 2018 | 11:10 PM
Vanessa Cazares-Ramos's Avatar
Default 2007 Hyundai Accent Check Engine Light P0301 Cylinder Misfire
My 07' Accent with about 37,000 miles had two codes pop up:
P0301
P0300
The people at O'reilys cleared them so the check engine light isn't on anymore.
The first spark plug was checked and it looks fine and the others were fine as well. The gaps were good. They were at 0.39. I don't know what else it could be since I don't know much about cars so what should I do next?
Any one had any previous experience with this?
Old Aug 20, 2018 | 06:05 AM
ampmadscientist's Avatar
Yes
Broken intake valve spring. Take off the valve cover and inspect the valve springs VERY carefully with a light and magnifier.
(it's hard to see a broken spring, so you need to check carefully)
I was able to remove and replace the spring with a small spring compressor. That fixed it.
ALL the usual stuff:
spark plugs, wires, injectors...was all a big waste of time and money. The intake valve was stuck open....that's all it was.
itsdiz
Dec 15, 2018 02:09 AM
gpandlf
Dec 31, 2008 11:23 AM
anonymouse
Apr 14, 2008 09:36 AM
spf150
Feb 11, 2007 03:43 PM
ibanez444
Dec 30, 2005 09:26 PM
