2016 Hyundai Accent sport green coolant
I have a 2016 Accent sport 6 speed manual roughly around 58,000 miles. I was going to change the coolant due to age and before winter time, it is green so suspect it is OEM coolant.
Is there a pre-mixed ready to use that is compatible version that is presently in it? I had bought this for a daily driver roughly 2 years ago however I am not driving it as much as working remote. thanks |
There is a pre mixed product available with "Long Life" feature.
Entire system needs to be drained , then new coolant added. |
Originally Posted by hanky
(Post 62274)
Yes, most of the time.
If unsure, check what your owner's manual states. |
I will check it out, I called up a dealer and most likely will go get the OEM green and get some distilled water and mix 50/50.
I wish they had it 50/50 like it seems for other coolants. Just easier to do as need another 1 gallon jug to do the mixing. thanks |
As soon as you start the engine the coolant gets circulated and if you install a gallon of straight anti freeze then add 1 gallon of water , it will mix it up very well.
Your main concern is to make sure you get all the air out of the cooling system when filling. |
(Post 62282)
Your main concern is to make sure you get all the air out of the cooling system when filling. thanks again, Scott |
