2016 Hyundai Accent sport green coolant
Old Oct 17, 2021 | 06:43 PM
arz71's Avatar
Default 2016 Hyundai Accent sport green coolant
I have a 2016 Accent sport 6 speed manual roughly around 58,000 miles. I was going to change the coolant due to age and before winter time, it is green so suspect it is OEM coolant.
Is there a pre-mixed ready to use that is compatible version that is presently in it? I had bought this for a daily driver roughly 2 years ago however I am not driving it as much as working remote.
thanks
Last edited by arz71; Oct 17, 2021 at 06:44 PM. Reason: working remote not driving as much
Old Oct 18, 2021 | 07:44 AM
There is a pre mixed product available with "Long Life" feature.
Entire system needs to be drained , then new coolant added.
Old Oct 18, 2021 | 09:17 AM
arz71's Avatar
Thank you for replying is the 'stock OEM' coolant the standard 'green'?
Old Oct 19, 2021 | 06:02 AM
Yes, most of the time.
If unsure, check what your owner's manual states.
Old Oct 19, 2021 | 09:36 AM
arz71's Avatar
I will check it out, I called up a dealer and most likely will go get the OEM green and get some distilled water and mix 50/50.
I wish they had it 50/50 like it seems for other coolants. Just easier to do as need another 1 gallon jug to do the mixing.
thanks
Old Oct 19, 2021 | 05:53 PM
As soon as you start the engine the coolant gets circulated and if you install a gallon of straight anti freeze then add 1 gallon of water , it will mix it up very well.
Your main concern is to make sure you get all the air out of the cooling system when filling.
Old Oct 19, 2021 | 06:55 PM
arz71's Avatar
Thanks Hanky - the closest dealer is about an hour or more from me so I will be getting it most likely next Mon/Tuesday. Really like this forum,
thanks again,
Scott
Mparker25
Oct 2, 2021 01:56 AM
princeinflorida
Mar 22, 2016 08:42 AM
homealone
Apr 25, 2015 05:38 PM
Mr. Pine
Oct 5, 2011 03:40 PM
zachunderwood
Dec 18, 2010 08:17 PM
