Rust in Coolant: 2000 Elantra 2L
Old Feb 21, 2016 | 07:47 AM
princeinflorida's Avatar
Default Rust in Coolant: 2000 Elantra 2L
I've had a problem over the years with the coolant becoming rusty and rust depositing in the coolant overflow reservoir. I use distilled water and Barrs Antirust/Waterpump Lubricant or a similar antirust from NAPA. I don't use antifreeze since I live in Florida. The antirust manufacturers say that this is OK.
Is there maybe a special antifreeze that might be a better antirust agent?
Also I notice that when opened cold, the radiator is not full to the very top, even with a new radiator cap and overflow reservoir at the full mark. I'm wondering if there may be a tiny head gasket leak allowing a small amount of exhaust gas into the coolant with resultant rusting from it's chemical action.
Any info would be appreciated.
Old Mar 1, 2016 | 01:05 PM
WholesaleHyundaiParts's Avatar
Former Site Vendor
I work at a Hyundai dealer in Florida and we always use the Hyundai coolant part number 00232-19010, I would not suggest anything else.
Old Mar 22, 2016 | 06:15 AM
e3tom's Avatar
= mistake #1
Deionized/distilled water promotes rusting
= mistake #2
Antifreeze is way more than just that. It cleans, lubricates, prevents cavitation & rust if used in the right concentration. Prefabricated water/antifreeze mixtures (as is the Hyundai coolant mentioned above) are the best/easiest, yet a little more expensive solution over mixing the components yourself.
Old Mar 22, 2016 | 08:42 AM
I would agree. Straight distilled water is not good. Buying the 50/50 pre-mix or using equal parts 100% antifreeze and distilled water is the best option. Like was said above, quality antifreeze isn't just to prevent the coolant from freezing.
pizzaman
Apr 20, 2012 06:48 AM
helimech
Mar 9, 2010 12:18 PM
ken2400
Jul 2, 2009 11:47 PM
ken2400
Nov 2, 2008 06:27 PM
Double J
Apr 5, 2008 12:16 PM
