36MPG?
My 2000 Accent (GS 1.5 AT) gets around 24 mpg. I just got it, and I've tried to increase the mileage because I drive a long distance to work. The reviews on the car all say it gets 36MPG on the highway new, so I would expect it would get around 30 now.
I've put on a SRI w/ cone filter. Replaced the fuel filter, plugs and wires, & put on new tires (6lbs under max). I've added Seafoam to the vacuum of the fuel injection, a little in the crank case and the fuel itself. I've also reset the computer.
Also, I drive around 65 on the highway to try to increase it.
Is there anything else I can change to make it more efficient? What about the PCV valve? I would like to think with a 1.5L engine, that I would get at least 30mpg!
I had no idea! The gas station I go to has two pumps (same price) but one says ethanol added. That's the one I've been using this whole time because I thought it was a cleaner, more efficient mix!
I'm not going to use that on my next fill up, and see if I notice a difference.
I still have one question though, what's the PCV valve do, and does it have anything to do with MPG?
PCV = Positive Crankcase Ventilation.It's basically a controlled vacuum leak that removes engine oil vapor and gas (blow-by) vapor out of the engine to burn it. If it's malfunctioning it can affect the MPG.
ORIGINAL: fannatick2
ethnol will kill up to 20% off MPG!
http://www.bendbulletin.com/apps/pbc...0107/804030435
But if you like to help the American Economy, then it shouldnt matter.
have you had your timing belt changed? how many miles on your car? we recently hit the 100,000km mark on our 03. had the timing belt changed as they suggested. our mileage in better then new. Recently went on a road trip. was at 661km pulled in to fill up (the fuel light had been on for a bit) it took 38L to fill it. Still 7L of fuel left.
ORIGINAL: Lucy 03
As for my wife's 2008 manual tranny Accent, she averaged 33MPG thru a cold long winter & hard commute. She let me take it for 3 daytrips over 1400, 3000, 4000, & 5500 foot mountain passes nailing down 41.5, 42.6, & 45.2 MPG!
Hopefully, MPG will go even higher at times.
So change your timing belt before you destroy your engine. & with careful driving, maybe your MPG will also go up!
Wow, timing belt you say? I'll look into that, i too am trying to squeeze every bit of millage out of my accent.
i've been lead to believe that a slightly bigger diameter exhaust will help too. Not too big because small engines like ours need that back preasure that and you don't want your car to sound like a pissed off weed eater.
and where are you supposed to find a gas station that doesn't have ethonol mixed in its gas? Look at the pump, its everywhere.
One thing you could try is Zmax, i swear by the stuff, i bought my car with 75K miles, was getting about 26mpg which at the time was great because i had a truck before it, but then i decided to try Zmax because of all the hype i heard on the speed channel, now i'm getting around 31mpg and the car has about 110K miles on it now. Plus the engine runs better, oil has seemed signifigantly cleaner, its just good stuff, and worth the money, it will pay for itself.
