Accent spark plugs
Old Sep 4, 2006 | 05:19 PM
greatbison's Avatar
Default Accent spark plugs
Quick question. I have a 2004 accent and I am about to come up on 40K miles. What is the typical life span of the factory spark plugs? Also, I do about 70 miles of freeway driving 4 times a week? Would it be worth upgrading to platinum plugs? I know that in higher end cars, they are mandatory but will the improve the little accent as well? Mainly gas mileage?
Thank you in advance
Old Nov 7, 2006 | 07:29 PM
wvjefo's Avatar
Default RE: Accent spark plugs
I replace my plugs twice a year. But that may be over doing it.
replace plugs every 15000 miles. I use Bosch plugs. A little more expensive but my car seems to like them
Old Nov 19, 2006 | 03:55 AM
00_ACCENT_MAN's Avatar
I change them every 30,000. Don't bother with platinum tip check get the spark plugs from the dealer.. OEM plugs work the best and you will get hte best milage out of the, I believe they are NKG R
Old Dec 3, 2006 | 03:28 AM
William Young's Avatar
I agree.
Use the NKG that your manual recommends. I bought my 2002 accent with 25K km on it. After a while it started running like crap.
I pulled the plugs out only to find that the previous owner had put Bosch platinums in it and one of the insulators was cracked from top to bottom causing an arc and another one had a small crack. I installed the exact NKG number from my manual and now have 82K km on it and still getting excellent mileage.
I think I will put new ones of the same kind in again in the near future just under general principles.
W.Y.
Old Jan 8, 2007 | 12:35 AM
dodgethis2000's Avatar
NGK's are good plugs. I'd run champions once I get my accent and the OEM's require replacement. Standard copper works great. I run them in all my current and previous vehicles (Ford, GMC, Dodge, Toyota), and small engine equipment. I wouldn't get platinums as the long 100 000km change interval seems like a long time, especially if the vehicle isn't driven often. I change the champions at 40K and they still look like they could last another 20-30K. I don't take chances on my maintenance. Every vehicle I've owned generally sees severe service and lasts well past 250K! The accent better last that long...
Old Dec 5, 2008 | 12:45 AM
Michaels10's Avatar
according to hmaservice.com
non platinum 30,000
platinum 60,000
I have a 3002 Accent what is the NGK #
is it NGK BKR5ES-1
Old Dec 5, 2008 | 12:46 AM
Michaels10's Avatar
better yet what is the hyundai part #
Jesse 420A
Aug 14, 2013 06:01 PM
KingEvil
Dec 5, 2008 12:48 AM
joe
Jan 17, 2008 07:35 AM
Boomer
Apr 23, 2006 03:36 PM
joe
Oct 24, 2005 01:26 AM
