Accent Troule Areas
Old Jun 4, 2006 | 05:04 PM
Gdawgs's Avatar
Default Accent Troule Areas
My brother and I are looking at an Accent(99' automatic, 80,000 miles) for his daughter. I noticed on Consumer Reports that they have some transmission reliability issues. Is there anything in particular that tends to be a problem with the transmissions?
Are there any other major issues specific to these cars(besides the obvious things you'd check for on any car) to check for?
Thanks
Old Jun 4, 2006 | 06:08 PM
hyundai tech's Avatar
Default RE: Accent Troule Areas
Get a service history. Make sure timing belt ect has been done.Some accents have had trans issues in those years.Main thing is has the car been serviced regularly?
Old Jun 20, 2006 | 03:23 AM
stokelife's Avatar
I have a 95-97 body accent.
The dor handles break off a lot and windshields break.
Also there were recalls b/c of rusty parts but if they dont put salt on the roads where you live dont worry
A lot will depend on the eact car your getting, engine and tranny wise the car is great
Old Jul 2, 2006 | 04:16 PM
greatbison's Avatar
With ANY used car at about that age/mileage, the thought of replacing the Automatic Transmission would be at the back of my mind. They all seem to go out at about 100K and that'll set you back a bit. Then again, you could get years of life out of it. If they've got maintainace records, read through them and see how often the transmission was cared for (fluid flushes and stuff). Hope this helps.
