Coupe Si 98' Knocking sound
Old Jun 19, 2007 | 09:42 AM
jducasse's Avatar
Default Coupe Si 98' Knocking sound
I am looking for some urgent help.
I have noticed a worrying knocking sound coming from the front LHS wheel, I will be removing it tonight to check for any loose or broken parts.
What I would like to know is if there is anything I may be missing that might not be visible via a quick (mildly experienced) look under the front.
The knocking occurs either part way through a corner or when going over sharp bumps which leads me to think it could be a bush, however there is a definate 'metal on metal' sound to the noise and it happened all of a sudden.
Any advice will be greatfully recieved.
Old Jun 19, 2007 | 11:14 AM
Doohickie's Avatar
Default RE: Coupe Si 98' Knocking sound
Have you ever had a CV joint fail? That sounds like classic CV joint symptoms. If that's the problem, it may drive for a while longer like that, or it could totally break at any time and you'd be stranded.
sajid44
Feb 20, 2012 10:41 AM
ybattack
Apr 16, 2011 06:33 AM
sheriffjonny
Oct 21, 2010 01:42 PM
Chas2001
Nov 25, 2007 11:23 PM
jducasse
Jun 19, 2007 09:38 AM
