Enginethings please help
I'm having trouble finding the name of a part. It's located near the wipermotor. Check engine light is on (P0422). I also want to know if I my ignition wires Are connected in the correct order.
If you google for P0422 it comes up as "Code P0422 indicates that the Bank 1 Main Catalytic Converter's emissions efficiency has fallen below the minimum allowable limit. This threshold is tracked by a Catalyst Monitoring Oxygen Sensor located on or near the outlet of the Catalytic Converter."
The other thing i have no clue what you talking about you got a picture or more precise description? what model/year of the car? |
Originally Posted by Karpov
(Post 51463)
The other thing i have no clue what you talking about you got a picture or more precise description? what model/year of the car? It's an accent 99 lc. I'll take a picture of the part i'm asking about asap ^^ |
Originally Posted by Jof
(Post 51464)
Yes, i know what the error code and that it could be the o2 sensor causing it. But could it be something else?
If i were you i'd test 02 Sensor resistance with digital multimeter to see if its okay or just get a new one however might worth testing they are pain in the ass to unscrew. |
1 Attachment(s)
It passed all tests last summer.
Had an issue with sputter a month ago, turned out to be a bad ignitioncable. I'm not sure I put them back in the right order... The picture is of that part. Know what it's for? |
1 Attachment(s)
I think its evaporation system solenoid used in returning vapors from gas tank to be burned inside engine, if you take it off which is easy then you can read the part number and put # trough google it will show you what part it is exactly.
It might give you check engine code if not working however its very optional and would not affect the engine operation. This is how ignition wires were on my car, but reference the manual to be sure google for "manual-de-despiece-hyundai-accent-98-1.5-SOHC pdf". |
(Post 51494)
Update. Replaced sparkplugwires. Error code gone. Car is running smooth. Made sure the evaporationthingy was plugged in correctly.
