Gear dependent humming
Old Oct 16, 2015 | 08:39 AM
Vox's Avatar
Vox
Default Gear dependent humming
I have an 09 accent with a 5spd manual at 63k miles.
I have recently started to notice a vibrating or humming noise when accelerating, but it seems that it only occurs in 4th gear. If you let off the sound significantly decreases, if not disappears. If I go into 5th gear its gone, same with 3rd. The clutch engages and disengages smoothly.
The dealership flushed and replaced the trans fluid approximately 1k miles ago. The timing belt was replaced, the coolant was replaced, accessory belts etc.
What could be causing this?
Thanks!
Old Oct 16, 2015 | 09:43 PM
avisitor's Avatar
A bad fourth gear?
Old Oct 17, 2015 | 04:34 PM
Vox's Avatar
Vox
It only seems to hum whenever it is cold. Once its warm it doesnt do it.
Old Oct 17, 2015 | 06:51 PM
avisitor's Avatar
Well, if only seems to hum then may be it only seems like a bad fourth gear
But, lets wait til it gets warmer before we decide what the problem really is ... hahahaha
Old Oct 17, 2015 | 06:59 PM
Vox's Avatar
Vox
Let me clarify, once it is driven for a while and has warmed up, the hum stops.
Old Oct 17, 2015 | 09:23 PM
avisitor's Avatar
So, are you saying you don't have a problem??
OceanLvr812
Jun 3, 2019 07:49 PM
magnus
Jun 8, 2011 07:24 PM
reman
Feb 2, 2011 05:04 PM
samjackson
Feb 18, 2009 01:18 PM
