heater blower/fan
Old Jan 5, 2009 | 06:33 PM
  #11
ken99's Avatar
Default RE: heater blower/fan
From http://www.hmaservice.com/:
REMOVAL
1. Remove the 2 heater side control cables and one blower side control cable.[/align]
2. Remove the center facia panel from the lower portion.[/align]
3. Disconnect the switch connectors and remove the center facia panel.[/align]
4. After removing the mounting bolts, remove the main crash pad. (Refer to "CRASH PAD" of BD guoup)[/align]
5. Disconnect the evaporator core temp sensor (thermister), blower resistor connector, and motor connector.[/align]
6. Remove the evaporator unit.[/align]
7. Remove the blower unit.[/align]
INSTALLATION
Installation is the reverse of removal. (Prior to installation of intake and exhaust cables, install the locating pin)[/align]
MAIN CRASH PAD[/align]
- When using a screwdriver or equivalent, wrap it with protective tape to prevent damage.[/align]
- Wear gloves to protect hands from injury.[/align]
Be careful not to scratch the crash pad.[/align]
1. Remove the steering wheel and airbag module.[/align]
2. Remove the glove box. ("See Page BD-38")[/align]
3. Remove the crash pad lower panel. ("See Page BD-37")[/align]
4. Remove the center facia panel.("See Page BD-38")[/align]
5. Remove the audio assembly.[/align]
6. Remove the crash pad side trim.[/align]
7. Disconnect the antenna connecting connector.[/align]
8. After loosening the main crash pad mounting bolts, remove the main crash.[/align]
9. Installation is the reverse of removal.[/align]
CRASH PAD LOWER PANEL REMOVAL AND INSTALLATION[/align]
1. Raise the steering column.[/align]
2. Loosen the 4 mounting. Disconnect the self-diagnosis connector and hood release cable and remove the crash pad lower panel.[/align]
3. Installation is the reverse of removal.[/align]
GLOVE BOX REMOVAL AND INSTALLATION[/align]
1. Remove the glove box stopper.[/align]
2. After loosening the glove box mounting screws(3EA), remove the glove box.[/align]
CENTER FACIA PANEL REMOVAL AND INSTALLATION[/align]
Take care not to scratch the crash pad.[/align]
1. Remove the glove box.[/align]
2. Remove the crash pad lower panel. ("See Page BD-37")[/align]
3. Disconnect the intake control mode, mode control, and air mix control cable. Remove the center facia panel from the lower portion with a trim remover.[/align]
4. Loosen the 4 mounting screws and remove the audio assembly.[/align]
5. Installation is the reverse of removal.[/align]
gary1452
Aug 13, 2014 10:47 AM
messybarnyard
Dec 11, 2008 07:06 AM
abaird1
Oct 1, 2008 09:46 AM
barking
Sep 23, 2007 12:53 AM
ruppenduro
Dec 7, 2005 10:16 PM
