Help!
Old Apr 26, 2008 | 01:28 AM
cassiesride's Avatar
Default Help!
2005 accent check engine light on. 19000 miles, no other problems, no other warning lights on. AAHHH
Old Apr 26, 2008 | 08:52 AM
cstephen's Avatar
Default RE: Help!
well then the first thing you need to do is take it to a shop and have them run an OBDII scan on it. Or, you can go to Autozone and rent an OBDII scanner for free, and within five minutes, you should know exactly WHY your light is on. Simply posting HELP! My check engine light is on, does not tell us anything. Is the car still running oK?
It could be something so simple as you forgot to tighten your gas cap all the way the last time you got fuel.
