Looking for accent 2008 radio & speaker removal guide
Old Apr 10, 2008 | 01:22 AM
flibottf's Avatar
Default Looking for accent 2008 radio & speaker removal guide
As the title says, I've been looking for diagrams or guides to change the stock radio and speaker on my new Accent 2008 L Hatchback.
Any help would be appreciated! I've been looking all over!
Old Apr 10, 2008 | 06:45 AM
Default RE: Looking for accent 2008 radio & speaker removal guide
REPLACEMENT[/align][/align]FRONT SPEAKER
1. Remove the front door trim panel (Refer to the Body group - front door).
2. Remove the front speaker (A) after removing 4 screws.
3. Installation is the reverse of removal. [/align][/align]REAR SPEAKER (3 Doors)
1. Remove the rear door trim panel (Refer to the Body group - rear door).
2. Remove the rear speaker (A) after removing 3 screws.
3. Installation is the reverse of removal. [/align][/align]REAR SPEAKER (4 Doors)
1. Remove the rear seat (Refer to the Body group - rear seat).
2. Remove the rear package tray (Refer to the Body group - rear seat).
3. Remove the rear speaker (A) after removing 4 bolts.
4. Installation is the reverse of removal. [/align][/align]TWEETER SPEAKER
2. Remove the tweeter speaker after disconnecting the connector(A).
Old Apr 10, 2008 | 07:05 AM
flibottf's Avatar
Thx! but where do I refer for body groups?
Old Apr 10, 2008 | 07:48 AM
Sorry about that:
REPLACEMENT
DOOR TRIM REPLACEMENT
[NOTE]
- Take care not to scratch the door trim and other parts.
- Put on gloves to protect your hands.
1. After disconncting the connector(A), remove the quadrant inner cover(B).
2. After loosen the inside handle cover mounting screw, remove the inside handle cover(A).
3. Loosen the door trim mounting screws. Disconnect the power window switch connector(A), power mirror connector(B). Remove the door trim(C).
[NOTE]
- Make sure of connectors is plugged in properly and each rod is connected securely.
- Make sure the door lock and opens properly.
Old Apr 10, 2008 | 08:10 AM
flibottf's Avatar
thx a lot! i found the wesite where you found the info.
QUite a daunting task, the center fascia doesnt get off with a wimple screwdriver....
Old Jan 6, 2009 | 06:04 PM
Mattmann's Avatar
Very helpfull info.
Any chance of a link to the website where the diagrams and info came from?
Old Jan 6, 2009 | 09:28 PM
http://www.hmaservice.com
dugdog
Sep 18, 2010 05:27 PM
Vic Hyundai...Veracruz owner
Aug 19, 2010 12:47 PM
05tibby
Jan 25, 2009 08:59 PM
adam1121
Nov 30, 2008 07:28 AM
eck5150
Apr 26, 2006 01:50 AM
