Map sensor
Old Jun 1, 2019 | 02:26 PM
ThurmanSavoy's Avatar
Default Map sensor
Where is the map sensor located on 06 accent
Old Jun 1, 2019 | 04:52 PM
Can we inquire why you are looking for a MAP sensor ?
Old Jun 1, 2019 | 04:57 PM
I got a code for a map/maf sensor I changed the maf and was just wondering about the map sensor
Old Jun 1, 2019 | 06:28 PM
Could you please tell us what the code(s) was? Sometimes a code will come up with the description involving MAP and the sensor is not always the fault. Maybe we can save you some addl work.
Old Jun 1, 2019 | 08:30 PM
P0068
Old Jun 1, 2019 | 09:45 PM
avisitor's Avatar
I had always believed that a car either had a MAP sensor or a MAF sensor ... not both.
So, I got to ask. Does your manual say there is both?
Old Jun 2, 2019 | 05:05 AM
I believe what the code is attempting to tell you is,
The reading the PCM is receiving from the MAF , which you changed, and the electronic throttle control are not rational, in other words, don't make sense.. One of them is off. That could have a few causes and usually a good idea to confirm all good connections first before replacing any parts. The ETC may be giving a rdg that doesn't agree with the MAF rdg. A dirty throttle blade might contribute to something like this.
Did you get any other codes like fuel trim , or rich or lean codes? What symptoms were you getting?
Old Jun 2, 2019 | 08:35 AM
Some Hyundai engines will have a MAF sensor and a MAP sensor,however, the MAP sensor in this application is used as a Baro sensor and is placed near the intake .and can be combined with the MAF sensor. The 4th wire is the tip off.
trvrgwn
Jan 31, 2016 11:54 PM
mfm2010acc
Apr 1, 2012 07:10 AM
tmac44
Jan 23, 2012 08:15 AM
aeroflyer711
Dec 21, 2011 03:54 PM
cbgeorge
Nov 16, 2008 08:33 PM
