No fluid from rear washer
Old May 22, 2020 | 10:51 PM
Beans's Avatar
Default No fluid from rear washer
I am not getting any fluid out of the rear window washer nozzle on my 2009 Accent hatchback. I disconnected the hose between the vehicle and the hatchback and confirmed that there is plenty of flow at that point, so clearly something is kinked/pinched/clogged in the hatchback tubing.
I had to get the vehicle inspected as it was from out of province, and one issue that had to be remedied was the non-functioning third brake light. I can't recall if the washer worked before the repair, but I suspect something wasn't hooked up properly or got kinked during the repair.
In an attempt to avoid just removing every panel *****-nilly, does anybody know how I go about removing the light and surrounding panels to see what I can find?
Old May 25, 2020 | 07:54 PM
Beans's Avatar
I figured it out. The hose was pinched between the spoiler and the hatch. There are five 10mm nuts that hold the spoiler on. Three are visible without removing anything, the other two are hidden under the plastic cover that goes at the top of the window.
srowena
Feb 16, 2019 08:17 AM
maXjrNC
May 3, 2018 07:02 PM
Dpbuch
Mar 17, 2011 03:45 PM
sarahinmedford
Jan 2, 2009 02:22 PM
JSAD10
Dec 27, 2007 10:38 PM
