Piston Slap Problems
Old Nov 8, 2004 | 01:53 PM
jerm's Avatar
Default Piston Slap Problems
I read on here about a problem called Piston Slap, due to a rebuild of the engine where it has been bored out an additional 0.010" and the piston can 'slap' around in the bore. </P>
It is indicated by a rattling or 'marbles' sound when the engine reduces cycling/idling after giving it gas and you remove throttle.</P>
</P>
Can this be fixed? Is it that large a problem. (Help me Dr. Hundi - I think you responded to this prob last time.)</P>
Old Nov 9, 2004 | 04:46 AM
Dr. Hundi's Avatar
I think you misunderstood.</P>
</P>
The engine needs to be taken out 0.010 with the 0.010 oversize pistons to overcome the piston slap problem.</P>
The piston to bore clearance was set incorrectly from the factory, which is why it develops this problem.</P>
If you log onto Hyundai-Forums.com, you will find a discussion on this topic which may assist you in your own diagnosis of this problem.</P>
Dr. Hundi</P>
http://www.hyundai-forums.com/index.php?showtopic=1029</P>
pjssae
Mar 30, 2011 06:31 PM
bek0r
Dec 7, 2005 04:55 PM
Tiburon100
Dec 6, 2005 06:17 PM
neta
Jan 21, 2005 12:23 AM
scrutineer
Oct 25, 2004 08:36 PM
