radio, clock, interior light
Old Aug 21, 2007 | 05:16 PM
fozzie99's Avatar
Default radio, clock, interior light
I have a 2001 accent 2 door hatchback. The clock, radio, and interior domelight died on this car. Is there a way to figure if these are all on the same fuse, or relay??? I have looked at both the fuse box in the engine compartment and the one on the driver's side kickboard near the clutch..... I have checked all the fuses and none seem shot. But I really couldn't find anything as far as a descriptionin either block refering to the clock or the interior dome light. One fuse in the engine compartment is marked "AUDIO" but it is not blown. Any help or guidence would be greatly appreciated!!
Thanks!
Stephen
Old Aug 22, 2007 | 09:14 AM
Doohickie's Avatar
Default RE: radio, clock, interior light
In the engine compartment, the fuse next to the AUDIO fuse is the ROOM LP fuse. That fuse controls the Audio (always-on memory), Instrument Cluster, Courtesy Lamps, Room Lamp (dome light), etc. Try that one.
Old Nov 22, 2007 | 03:46 AM
Michaels10's Avatar
Default AUDIO&ROOM LP FUSE
Whats the story with the little yellow plastic fuse doubler on theAUDIO and ROOM LP fuses how do you get the fuses out pull the whole thing or use tweezers to get out each fuse
Old Nov 22, 2007 | 03:47 AM
Michaels10's Avatar
Default RE: AUDIO&ROOM LP FUSE
its 2002 Accent by the way
Old Nov 22, 2007 | 08:33 PM
Doohickie's Avatar
Not sure what you mean; maybe a photo would help.
Old Nov 23, 2007 | 09:49 PM
Michaels10's Avatar
heres picture
[IMG]local://upfiles/672/3AE36EED867645B2B7042B002DDF1036.jpg[/IMG]
Old Nov 23, 2007 | 09:52 PM
Michaels10's Avatar
another photo
Old Nov 24, 2007 | 09:42 PM
Doohickie's Avatar
Have you tried squeezing on the two sides of the yellow thing and seeing if the whole thing comes out with the fuses?
Old Nov 25, 2007 | 06:30 PM
Michaels10's Avatar
yes I tried that but it did give then I tried pushing them away the both times the whole fuse box was moving so I didnt want to put too much pressure to it
Michaels10's Avatar
oops sorry I meant it didnt give when I messed with tabs
