Rough idle
Old Apr 4, 2012 | 03:16 AM
mahinakane's Avatar
Default Rough idle
I have a 2003 Accent with 64,000 miles on it. I bought it used and it was great for a couple of weeks. Then the coil (looks original) went out so replaced coil, plugs and wires. Thanks to the forum fixed the slow fill problem. Now I'm having a rough idle problem. Sometimes at idle the R's will drop and the engine runs rough. Sometimes when slowing down or accelerating from a stop, the engine will lose power. I have changed the idle control valve and the purge solenoid. I enjoy the car so I hope that I can get it running right.
Old Apr 11, 2012 | 03:17 AM
mahinakane's Avatar
Default update
I replaced the TPS and the idle doesn't seem as rough but still not running right.
Old Apr 15, 2012 | 09:46 PM
laughingoddess's Avatar
Default check engine light on?
If your check engine light is on and reads tps - i had that problem and i had the intake gasket replaced and that fixed it! its a lot of work if that isnt the problem though.
keiffer
Jun 9, 2006 12:02 AM
nmedeiros
Jan 18, 2006 02:48 AM
dave1234
Dec 22, 2005 09:36 AM
ogman99
Sep 27, 2005 07:45 PM
L2rocku2
Aug 3, 2005 12:57 PM
