start up rattle
Old Jul 24, 2013 | 12:06 AM
obrian's Avatar
Default start up rattle
Hi, I have a 06 four door accent .Automatic . My wife loves her little car. It has 52k and runs well. It get terrible mileage but she loves it. The sway bar links are bad so it clicks over every bump.
Now it has started to do a rapid, tight rattle for a second upon startup. Not every time, but its getting more regular. I have read about the tensioner on the timing belt, its seems too early for a replacement.
I have googled and read a lot but as yet have not heard anyone having this rattle. I just changed the oil and filter and no change. I tried it without the a/c on and it still does it.
it sounds like its coming from the drivers side down low...always the same sound....short and quick, like a oil pump up rattle.
I have a few cars, she loves this one. Any ideas
obrian
Old Nov 10, 2013 | 08:44 PM
fishnbarge's Avatar
I have the same problem did you find out the problem yet. i have 100,000mi runs perfect and gets 29mpg
Old Nov 11, 2013 | 10:10 AM
obrian's Avatar
Default accent rattle
I have changed the oil, looked for loose things. I have not taken it to a dealer as they want money to look at it. It just does it on occasion....cold starts or warm.
when i get to the dealership i will post what it is.....
brian
Old Nov 12, 2013 | 09:16 AM
Are you using a Hyundai oil filter or an aftermarket brand?
Old Nov 12, 2013 | 10:51 PM
fishnbarge's Avatar
Default rattle
I use fram filters. Ive been using fram since the car was new. It developed the rattle at around 80k mi and only when cold.
Old Nov 13, 2013 | 06:39 AM
I don't know. I wouldn't use Fram filters and I know they have caused problems on other cars. See this TSB:
Old Nov 14, 2013 | 08:49 AM
obrian's Avatar
I am going to try the new filter....if there is no check valve to help keep pressure in the system then the start up rattle is now understood.
I shall keep you appraised of any developments on this front.
Old Nov 14, 2013 | 09:19 AM
The problem isn't the check valve it's that some aftermarket filters are more restrictive and the oil flow is reduced.
Old Nov 16, 2013 | 05:54 PM
fishnbarge's Avatar
Default rattle
Is there a port where i can connect an oil pressure gauge
berbes
Apr 20, 2007 09:14 PM
jtaylor
Apr 2, 2007 12:53 PM
emtbch
Jul 2, 2006 07:58 PM
HUSTLER2677
Mar 31, 2006 03:47 PM
djs1967
Jul 30, 2005 04:12 AM
