Starting issues after putting gas in.
I need help I am having issues starting my 2006 hyundai accent after putting gas in. I have already put a new purge valve in. It starts after I crank it with my feet on the gas and brake when I put it in drive. Then it will start up everytime after that no problems. I have no check engine light on now after replacing the purge valve. Please help.
Don't understand what the problem is.
You say you replaced the purge valve and it starts. And it starts every time after that What issues are you having? What help do you need? |
Originally Posted by avisitor
(Post 54185)
Just guessing, it sounds like a fuel issue.
It could be a lot of things causing this Dirty MAF sensor Clogged exhaust Vacuum leak Faulty O2 sensors Faulty Idle Air Sensor Faulty fuel pump Dirty gas tank/clogged sock or fuel filter I wouldn't go changing parts until I am sure that it will fix the issue Test, test, test ... Good luck |
Wouldn't it give me a code if something was faulty?
Not all the time.
It takes two drive cycles for the ECU to put on a check engine light Pending codes might have something but not always |
