Starting issues after putting gas in.
Old Mar 19, 2018 | 02:52 PM
Ace1750's Avatar
Default Starting issues after putting gas in.
I need help I am having issues starting my 2006 hyundai accent after putting gas in. I have already put a new purge valve in. It starts after I crank it with my feet on the gas and brake when I put it in drive. Then it will start up everytime after that no problems. I have no check engine light on now after replacing the purge valve. Please help.
Old Mar 19, 2018 | 04:49 PM
avisitor's Avatar
Don't understand what the problem is.
You say you replaced the purge valve and it starts.
And it starts every time after that
What issues are you having?
What help do you need?
Old Mar 19, 2018 | 05:36 PM
Ace1750's Avatar
it starts with my foot on the gas, otherwise it'll die if I don't. Only when I put fuel in it has a rough time starting.
Old Mar 19, 2018 | 10:45 PM
avisitor's Avatar
Just guessing, it sounds like a fuel issue.
It could be a lot of things causing this
Dirty MAF sensor
Clogged exhaust
Vacuum leak
Faulty O2 sensors
Faulty Idle Air Sensor
Faulty fuel pump
Dirty gas tank/clogged sock or fuel filter
I wouldn't go changing parts until I am sure that it will fix the issue
Test, test, test ...
Good luck
Old Mar 19, 2018 | 10:49 PM
Ace1750's Avatar
Wouldn't it give me a code if something was faulty?
Old Mar 19, 2018 | 10:55 PM
avisitor's Avatar
Not all the time.
It takes two drive cycles for the ECU to put on a check engine light
Pending codes might have something but not always
Dr.007
Jan 22, 2013 01:39 PM
tomwinwa
Aug 11, 2011 02:15 PM
3p4145
May 26, 2010 06:08 PM
surfguy17
Apr 6, 2010 06:57 PM
lovemyfe
Jul 17, 2009 04:01 PM
