Subwoofer
Old Jan 31, 2008 | 12:36 PM
noobliterator's Avatar
Default Subwoofer
I have a 2007 Accent 3dr and I also have a Bazooka tube. I wish to combine the two in a combination of awesomeness.
However I have NO idea how to hook it up to the existing stereo, and I was hoping that someone could help me with that, I can do all the other wiring, I was just never the one to hook it to the stereo. Any help you can give me would be much appreciated.
Thank You,
Noobliterator
Old Feb 1, 2008 | 07:49 AM
Default RE: Subwoofer
Nobody here has any idea how to get at the back of the stereo?
Old Feb 7, 2008 | 12:36 AM
squires500's Avatar
the bezel just pops off ...i would suggest a very small screw driver and a towel...pry from the bottom about an inch or so from each side ...do not pry from the top the dash is cheaply made and will damage(trust me on this one)
once thats off ...should only need to remove a couple screws that mount the stereo and then unplug the harness and antenna
thats apparently how you remove the facier it normally along those lines, at which point i assume that you are installing a sub of some desciption, you will need to run rca's from the back of the head unit to the amp as well as the remote line.
i personally have not seen a new model accent or their stereo but in general it is much easier to work with aftermarket stereos to add additional equipment as the stock stereos are hardwired.
but it depends on the config of whats there already. does the car have an existing amp? if so you can just daisy chain to the next amp and run the sub.
neway my 2c is put in a dedicated amp for the sub it will give you a much better sound an configuration also you wont massively underpower it and end up with masses of distortion.
Old Feb 7, 2008 | 12:42 PM
UPDATE: I have installed the bazooka tube and it works perfectly. If anyone else needs help with it just let me know and I can walk you through it.
bfkf95
Jan 3, 2024 07:53 PM
Supertom
Aug 31, 2007 02:13 PM
mikibark
Aug 30, 2007 09:36 AM
mikibark
Jan 15, 2007 10:41 AM
libertyboy17
Oct 11, 2006 04:00 AM
