Sunroof crooked / uneven 2010 Accent
Old May 12, 2020 | 07:51 AM
flykol's Avatar
Default Sunroof crooked / uneven 2010 Accent
The right side of the sunroof sits higher than the left side, Any quick fixes before I make it worse trying to fix it? Are there two motors? I read something about a reset procedure for an Elantra, but nothing for a Accent.
Old Jul 7, 2024 | 11:28 PM
Seanrig's Avatar
Default Same issue please respond
I have just got the same problem on mine. Did you find a fix for it? Was it from a dealer? Was it fixable on your own?
Old Aug 2, 2024 | 01:10 AM
Yernaz's Avatar
You can start by checking for any adjustment screws or bolts around the sunroof frame that might help level it out. While there might not be a specific reset procedure for the 2010 Accent, resetting the sunroof by turning the ignition on and holding the switch in the closed position for a few seconds can sometimes help. Also, make sure the sunroof tracks are clean and free of debris, as this can affect alignment. If you find any broken parts or are unsure, consulting the service manual or getting professional help might be the best way to avoid making the issue worse.
Soccerguy
Oct 20, 2019 10:35 PM
marks
Jun 7, 2017 09:15 AM
wildstng80
Jun 13, 2015 04:40 PM
toddJ
Aug 4, 2014 01:22 PM
mom2dbl
Oct 6, 2009 09:18 PM
