Tube Assembly Feed Hose Hookup Help Needed | 2012 Hyundai Accent GLS
Hello All, |
I don't think it matters.
If the manufacturer went by some general set-ups, hot fluid usually goes in the upper connection gets cooled and cooler fluid is returned to the component/system.
If it is different , they might have a particular reason for it . Sometimes you can confirm the original position by the length of the hoses. |
Put in the year and model at Hyundaioemparts.com
And then put in 45264 it comes up with TUBE Assembly-FEED - Hyundai (45264-26100) This does not fit your 2012 Accent. Strange??? |
