Tube Assembly Feed Hose Hookup Help Needed | 2012 Hyundai Accent GLS
Hello All,
I'm fixing my son's car after an accident and I failed to label the oil cooler hoses to know which goes where. I've attached a photo showing the radiator and tube assembly feed.
Help would be appreciated. Thank you!
If the manufacturer went by some general set-ups, hot fluid usually goes in the upper connection gets cooled and cooler fluid is returned to the component/system.
If it is different , they might have a particular reason for it .
Sometimes you can confirm the original position by the length of the hoses.
