Where Is The Oil Pan Drain Plug??
Yesterday, I was to change the oil inour 1.6 liter2007 Accent. I accidently drained the tranny; the pan looked just like an oil pan!
Anyway, I see two other plugs that look nothing likeany oil pan I've ever seenand want to be certain I get the correct one. I believe it is on the passanger side,cast aluminum with cooling louvers in the bottom, close to being under the oil dipstick with the drainplug facing rear. Is that the oil pan? |
RE: Where Is The Oil Pan Drain Plug??
That sounds correct.
Part #5 is what you are looking for: http://www.hmaservice.com/data/Passe...G/bcjf007a.gif |
Whoot! Thanks, man.
I accidently drained the tranny |
Yep. It needs to be SP-III.
Do you have a similar drawing for the transmission plug too you can post?
Carnac the Magnificent isn't a member here. Please tell us what car, model year and transmission.
Sorry about that. Mine is a 2009 Accent with manual transmission.
2009 manual trans:
Fill plug: http://www.hmaservice.com/data/Passe...G/bmjf002a.gif http://www.hmaservice.com/data/Passe...G/lkgf002f.gif Drain plug: http://www.hmaservice.com/data/Passe...G/lmjf001a.gif |
