Hyundai Azera A Hyundai like you've never seen before.
Fuel Pump
Old Mar 12, 2019 | 11:48 PM
J Noah Choos's Avatar
Default Fuel Pump
Hi,
Replaced fuel pump and filter in car with 153000 and get crank but no start. Bench tested pumps with both firing/working. Pumps never primed with key turned. Just wondering if it's a ground issue or possible ECU fault. Voltage to pump harness around 11V. Thanks!
Old Mar 13, 2019 | 06:48 PM
avisitor's Avatar
Check fuel pressure at injector rail..
Check for spark and injector pulse
Old Mar 14, 2019 | 04:00 AM
In checking back by the pump, If you have power there (12 volts) coming in on the correct wire to the pump motor it should run. A good possibility, ground is either poor or absent altogether, Equally important as power or the circuit is not complete and cannot function.
Caleb Green
Jul 18, 2019 04:15 AM
1OldDude
Jan 24, 2018 10:30 PM
makowski306
Nov 7, 2017 03:19 PM
madscientist
Jul 29, 2011 06:35 AM
Leejr57
Nov 18, 2006 09:06 PM
