04 Elantra A/T hard shift first to second
Old Aug 14, 2013 | 06:36 PM
Td00603's Avatar
Default 04 Elantra A/T hard shift first to second
I have an 04 Elantra that goes into all the gears fine but is hard shifting from first to second only. If I manually shift the trans it will shift ok only shifts hard when in drive anyone have any suggestions it would be appreciated thank you.
Old Aug 14, 2013 | 10:32 PM
tjvjr's Avatar
Do you have a CEL ? It could be a few things , scan or have it scanned for stored codes.
Old Aug 31, 2013 | 06:13 AM
Erichshonda's Avatar
Have you replaced or disconnected the battery before this occurred?. What you can try is disconnect both battery cables and perform a capacitive draw witch intales simply touching both cables together for about 30 seconds. MAKE SURE BOTH CABLES ARE DISCONNECTED from battery when doing this. This resets the adaptives. Then drive with a steady throttle at about 25%. Let trans goes through all gears. Do this 4 to 5 times and see if that helps
kchamb1206@yahoo.com
Jul 18, 2010 01:06 PM
mike
Sep 13, 2008 11:34 AM
Metalshark
May 27, 2008 06:44 PM
lutontownfc
Jun 15, 2006 08:59 PM
sudsy
Dec 7, 2005 04:12 PM
