'08 elantra heat stays on
Old Apr 21, 2012 | 05:55 PM
Dave08elantra's Avatar
Default '08 elantra heat stays on
My '08 elantra limited (with 120k) heat stays on and gets unbearable quickly.
Old Apr 22, 2012 | 10:39 AM
Ah....can you give a little more detail? Is the temp dial turned all the way to cool? Have you turned the mode selector to OFF? What is the temp reading for the engine?
Old Apr 23, 2012 | 06:40 PM
I've tried the temperature settings on max and min, turned the system off, no change. The engine temp is normal. My only relief is to turn off the fan and open a window. It's a climate control system, you set the temp and it keeps it there with heat or a/c depending on the need.
Old Apr 24, 2012 | 07:06 AM
So you have the automatic climate control. Something is probably wrong with the temp sensors or the control module. Probably won't be cheap to fix.
Old Apr 25, 2012 | 06:40 PM
woulkd it show up as a fault on a OBD scanner? I'd probably go and buy one.
Old Apr 26, 2012 | 06:47 AM
No. That's not something OBD scans.
Old Apr 27, 2012 | 01:11 PM
Is there a way I can check myself?
Walester
Apr 13, 2014 12:54 AM
kevin01
Apr 10, 2009 01:14 PM
bigrob
Oct 18, 2008 12:29 AM
omgwtf
Oct 15, 2008 03:27 PM
rico
Mar 19, 2008 05:22 PM
