2001 Elantra OBDII port/adapter
Old Jul 29, 2009 | 05:53 PM
Houndog101's Avatar
Question 2001 Elantra OBDII port/adapter
Have a friend with a check engine light on, Where is the OBD port and is it standard or where would I get an adapter to use my scanner ?
Thanks, Ted O.
Old Jul 29, 2009 | 06:18 PM
All OBD-II are standard and they are usually located under the dash by the steering column.
Old Jul 29, 2009 | 08:40 PM
Houndog101's Avatar
Yes, I know that, where is it on the Elantra ? There is a connector but, it is not the Standard OBDII connector,, if thats it where would I get an adapter ??"
Old Jul 29, 2009 | 09:13 PM
I thought I answered that already:
You don't need an adaptor. All OBD-II use the same connector. If what you are looking at doesn't look like an OBD-II connector then you are looking at the wrong thing. You are probably looking at the keyless entry connector.
Looks similar to this:
Old Jul 30, 2009 | 01:40 PM
Houndog101's Avatar
Thanks Bud, now you answered it... I am seeing the wrong connector.. I'm just a Ford guy trying to help a friend that just got this Elantra...
Old Jul 30, 2009 | 02:11 PM
No problem. OBD-II is standard for all cars; GM, Ford, foreign, etc. The connector is the same and the codes are standardized. The original OBD has a different connector but all cars built after 1996-98 timeframe all use the same OBD-II.
Old Aug 2, 2009 | 08:22 PM
WillPartHyundai's Avatar
As Nova already said it twice, all the OBDII connectors are all the same, or call it standard - 16 pins.
The Male connector is J1962-M.
Joemec
May 16, 2016 12:32 AM
brucelittle9432
May 4, 2015 09:58 PM
RichCasale
Oct 8, 2010 11:51 PM
matt2655
Feb 10, 2008 07:03 PM
elantrai
Jul 25, 2006 11:46 PM
