2002 Elantra question on valve lifters
Old Oct 15, 2011 | 04:07 PM
petraman7's Avatar
Default 2002 Elantra question on valve lifters
I putting the head assby back on my 02 elantra and noticed that all of the lifters are the same except one. This one has a slightly recessed head and a round 1/2 " ( 12mm) detent in the center.
It's NOt from wear. It's way too symmetrical .
Anyone seen this before?
Thanks, Scott in Vermont
Old Oct 31, 2011 | 03:38 PM
markmany's Avatar
Can you post the pic of it? I can help you then.
Old Nov 1, 2011 | 07:03 AM
petraman7's Avatar
Default Elantra lifter
It would seem that the "weird" lifter is actually the proper replacement for the original.
Old Nov 15, 2019 | 05:59 PM
427troy's Avatar
Wink bad lifter
it is symmetrical, because it is wear. That's a bad lifter, and probably the cam lobe too. Replace the lifter and lash adjuster, adjusting the valve lash in the process. good luck.
OkieH2
May 21, 2016 11:35 AM
eddy
May 4, 2016 08:58 AM
vrodd
Feb 4, 2016 02:40 PM
Striker
Dec 4, 2011 05:29 PM
Rhondas
Jul 21, 2009 09:20 PM
