Hi there,
I'm not sure if anyone can help me but I think it's worth a try.
1. The rear of my car makes an excessive clunking sound all the time. I'm pretty sure it's the trunk. Has anyone else had a similar problem? If it is the trunk, can it be fixed?
2. When I turn a corner hard to the right there is a scratching sound that sounds like its coming from the suspension. I have no idea what could cause this.
3. My steering wheel vibrates like crazy over level roads at highway speeds. I know it's not the tire balancing because I just replaced the tires and it doesn't do this at lower speeds. Any ideas?
I have a 2003 Elantra GT in Canada with 81000km (50000mi?)... 5 spd. manual.
Thanks!
Steven
Thanks!
Steven
if you balanced the tires and still vibrates at high speeds that mean the tires have bad belts in them. suspension noise check sway bar bushings in rear. as i can't see the car this is just my 2 cents.
