2004 Elantra. Accidentally broke electrical connector. What is it?
Yes, I just broke it too. Did you break the plug that goes into it also? I did. I had to get a replacement plug from the junkyard. Each time I gently removed the plug from a car at the junkyard, it would break and I had to remove 4 of them to finally get one that didn't break that much. Soldered the wires on and got a new timing oil control valve put in. Be gentle when putting the plug into it. Make sure there is a little rubber gasket that fits in the connector plug. If it's not positioned correctly, it will break the connector to the oil control valve, which is what happened to me.
