2007 Elantra with Front End Problems
Old Jan 29, 2009 | 06:46 PM
billphil's Avatar
Default 2007 Elantra with Front End Problems
I recently bought a 2007 Elantra with less than 30K miles on it. I like many things about the car, but not its ride. Specifically, the front end is both stiff and loose feeling (a bad combination), exagerating the bump in every expansion joint or pothole. [:@]
The front tires were new when I bought the car, and now I think the front driver-side tire may be slightly cupped, afterlessthan 5K milles.At highway speeds,that wheelfeels particularly loose, even slightly shaky.
I realize many factors (alignment, balance, etc.) can cause these symptoms, but before Ibring the car to the dealer I'd like to know if anyone has personal experience or special wisdom about front end issues with 07 Elantras.
Any help welcome. Thanks.
Old Jan 29, 2009 | 07:25 PM
jsinton's Avatar
Banned
Default RE: 2007 Elantra with Front End Problems
[align=left]Sounds like you have "hard" struts like I did. My 99 Elantra had struts so hard they wouldn't give at all. I replaced them and the tires at the same time, now all is well. You have to check the ball joints and tie rod ends, but probably they are ok since it's only 30k. After doing struts, an alignment is in order too.
[/align]
ElantraMan
Jan 1, 2020 08:14 PM
sonatalover
May 31, 2007 02:29 PM
nbrsguy
May 18, 2007 03:10 PM
sschenk
Mar 27, 2007 05:27 PM
GOLD07
Feb 23, 2007 12:53 AM
