-   -   2013 Hyundai Elantra 1.8 (P0340 and P0365) (https://www.hyundaiforum.com/forum/hyundai-elantra-17/2013-hyundai-elantra-1-8-p0340-p0365-19950/)
Manupnorth Jun 18, 2022 11:36 AM
So Elantra won't start this morning. I'm a Chevy guy so Hyundai's aren't my specialty. Trying to diagnose it so I went all over the internet and forums and I am at a roadblock. I replaced both camshaft sensors A and B.
didn't start. So I started checking voltages on camshaft sensor A (furthest away from firewall). I have 7 volts on the center pin and 12v only on one side of the outside pins. Same measurements for sensor B. Any ideas on what I can check next?
hanky Jun 18, 2022 01:27 PM
There is a good chance that there is a problem involving the VVT system (Variable valve timing).
It could be connections or maybe the solenoid that regulates cam position or a phaser problem. Without a capable scan tool, you can get into a rabbit hole replacing good parts.
Suggest you have a competent shop do some checking and provide a reason and cost to repair.
Manupnorth Jun 18, 2022 08:08 PM
Do you or anyone know where the wire for the camshaft A goes? Hoping to at least look for a bad connection at a plug or something but looks like it's a trip to the shop.
hanky Jun 18, 2022 08:21 PM
The camshafts are monitored by the sensors who in turn relay their position to the PCM ( Powertrain Control Module) When signals are not rational or non existent the PCM will notify the operator by way of a code or codes. It is up to the tech to determine just what is or is not happening
Manupnorth Jun 18, 2022 08:23 PM
This is why I like my older Chevy. Nowhere near as much computer crap. Thanks!
hanky Jun 19, 2022 08:27 AM
Something to think about,
There are times when a bad alternator will put out bad electronic signals that caused false camshaft codes to appear. that should give you some idea of what you are working with these days.
