2013 Hyundai Elantra 1.8 (P0340 and P0365)
Old Jun 18, 2022 | 11:36 AM
Manupnorth's Avatar
Default 2013 Hyundai Elantra 1.8 (P0340 and P0365)
So Elantra won't start this morning. I'm a Chevy guy so Hyundai's aren't my specialty. Trying to diagnose it so I went all over the internet and forums and I am at a roadblock. I replaced both camshaft sensors A and B.
didn't start. So I started checking voltages on camshaft sensor A (furthest away from firewall). I have 7 volts on the center pin and 12v only on one side of the outside pins. Same measurements for sensor B. Any ideas on what I can check next?
Old Jun 18, 2022 | 01:27 PM
There is a good chance that there is a problem involving the VVT system (Variable valve timing).
It could be connections or maybe the solenoid that regulates cam position or a phaser problem. Without a capable scan tool, you can get into a rabbit hole replacing good parts.
Suggest you have a competent shop do some checking and provide a reason and cost to repair.
Old Jun 18, 2022 | 08:08 PM
Manupnorth's Avatar
Do you or anyone know where the wire for the camshaft A goes? Hoping to at least look for a bad connection at a plug or something but looks like it's a trip to the shop.
Old Jun 18, 2022 | 08:21 PM
The camshafts are monitored by the sensors who in turn relay their position to the PCM ( Powertrain Control Module) When signals are not rational or non existent the PCM will notify the operator by way of a code or codes. It is up to the tech to determine just what is or is not happening
Old Jun 18, 2022 | 08:23 PM
Manupnorth's Avatar
This is why I like my older Chevy. Nowhere near as much computer crap. Thanks!
Old Jun 19, 2022 | 08:27 AM
Something to think about,
There are times when a bad alternator will put out bad electronic signals that caused false camshaft codes to appear. that should give you some idea of what you are working with these days.
bpt513
Nov 3, 2022 11:24 AM
freedaaronm
Mar 25, 2022 09:43 AM
cngodfather
Nov 29, 2021 07:35 AM
cartroublefindsme
Jan 8, 2019 01:09 PM
